Error ECM-P200200
2 Posts 2 Posters 972 Views
    Austris96
    Volvo V90 D5 (240k odo)
    Error ECM-P200200 Any ideas for solution ? This error appears after ~100km. Only this error.
    By side vdash cant read 1) heated catalyst 2) dpf readiness
      This error code means you have either a cracked/damaged DPF, or a defective particle sensor.
      The readiness codes should be green after you drive the car for a while.
