V50 P1 - Language change + key reprogramming without original key codes
45 Posts 3 Posters 5.8k Views
    replied to aiveo on last edited by
    @aiveo to code a new ignition key you first have to decode the IMMO pin. This 118674.png should be the option, if my translator is correct. After that you can add new keys. The key wizard allows to just add the key without having to pair the remote part. Vdash should also show you how many keys and remotes are currently paired with your car.
    "Engine service required" means there is one or more active error codes (DTCs) stored in the engine control module (ECM). You should see them after connecting Vdash and wait for all ecus to load. Best practice is to make a screenshot of all codes shown and clear them (ignition pos. II, ignition on, engine not running!). After that turn off the ignition for a moment, than start the car and rev around 1500 RPM for a moment, than read codes again and see what codes came back.
      @aiveo I just noticed you already cracked the IMMO. Just run the key wizard then, and don't forget to attach a good charger to the car while doing this.
      • A Offline
        A Offline
        aiveo
        Thank you for the detailed answer!
        I decoded the IMMO pin and used the key wizard. At step 3 (Actions no. 3), when inserting the faulty key into the ignition, I get 'No key detected [11]'. I suppose this confirms that the ID48 transponder chip in the faulty key is dead. I already ordered the replacement ID48 chip from your shop, so I'll swap it and try again.
        However I'm not sure how to physically replace the ID48 chip in the key. Do you have any guide or tips on how to do this? Is it in ths part of the key ? I can't find a solution to open this part of the key.
        For the engine codes I'll follow your procedure and report back.
          @aiveo https://youtu.be/JeP1lWSfAdA?is=YTg6CEC980bYtC5_ here is a video how to do it
          • A Offline
            A Offline
            aiveo
            Okay i have to buy a new case, thank a lot
              @aiveo another option would be to drill a hole from the front, remove the old transponder, and glue in the new one.
              The original key seems to be not meant for a transponder exchange, so Volvo can make more money with selling a complete new keyfob plus coding. 🙄
                Mustapha
                Bonjour ,
                Je me permets de posté afin de savoir où vous avez eu ce cable accompagné du logiciel pour modifier la langue .
                Salutations
                  replied to Mustapha on last edited by
                  @Mustapha the software https://d5t5.com/sw/vdash.exe
                  The adapter https://d5t5.com/eshop/detail/180/super-j2534-volvo-dice-9513000-replacement
                  You will also need a powerfull charger and lots of patience as you first have to crack the CEM pin, which can take up to 24 hours, sometimes even up to 180 hours.
                  On what car do you want to change the language?
                    Mustapha
                    Bonjour et merci de votre retour. Sur un Volvo v50 de fin 2011.
                    Savez vous si on peut baisser le volume du radar de recul . Il sort du petit haut parleur super fort . Ou il ya le siège bébé...
                      Mustapha
                      De quel chargeur parlez vous ?
                        #17
                        @Mustapha You need to attach a charger to the battery while decoding the CEM and also while coding/programming the car. The charger needs to be able to maintain a constant load of 8-10 Ampere for hours. This means you need a charger with at least twice the peak power (16-20A) of that. I'm using a CTEK PRO25S for example. Stay away from noname brands.
                          @Mustapha Try to turn the volume control in the center console, while your hear them beeping. The one for the radio.
                            #19
                            @Mustapha You won't need to decode the CEM, if you just want to change the language in the dash and radio. This can be done by Vdash without cracking. Simply connect the car, click on the language menu in the top right corner and follow the instructions. You might want to look here https://d5t5.com/partners for a vdash partner near you, that can do this for you.
                              Mustapha
                              Bonjour , je suis vraiment ravi d'échanger et que vous m'aider à avancer .
                              Donc pour le volume du radar de recul j'ai tenté mais ça ne changeait rien de mémoire .
                              Pour le changement de langue j'ai vu après votre lien pour des personnes proche de chez moi. J'attends leur retour .
                              Cependant vous me dites que que je peux changer moi même la langue sans piratage . Donc avec un câble que je peux avoir sur le net ?
                              Salutations et merci encore de votre aide
                                Mustapha
                                J'ai téléchargé v dash mais je n'arrive pas a me connecter.
                                Le site paraissait hors connexion. Je rentre mon mail mais pour le mot de passe je n'ai pas de case pour le rentrer.
                                Merci de votre aide encore une fois
                                  #22
                                  @Mustapha Than take a look at the manual which can be found here https://www.volvocars.com/fr/support/car/v50/10w46/
                                  If you just want to change the language, you just need the adapter I posted, and a charger. No time consuming pin cracking required. If you are lucky, it is even possible for free, but usually it will cost a small fee.
                                  And don't even think about programming your car without a charger attached. The V50 is really sensitive to undervoltage and will turn into a giant paper weight, when the battery voltage is getting too low.
                                    Mustapha
                                    D'accord pour le maintien de charge .
                                    Pour le site v dash il ya une procédure pour s'y connecter ? Je n'arrive pas a rentrer dedans .
                                    Merci
                                      Mustapha
                                      Finalement j'ai réussi. J'avais mal vu l'onglet a droite
                                        Mustapha
                                        Bonjour je viens de recevoir mon câble et installer les pilotes . J'arrive a communiquer avec vdash c'est génial
                                        Cependant dois je attendre un ticket via le site où je peux payer directement quelque part sur le logiciel ?
                                        Une personne m'avais parler de 29 euros .
                                        Or sur le logiciel vdash ça me demande une facture de 39 euros
                                        Merci a vous
                                          #26
                                          @Mustapha Changing the language costs between 0 and 150 Euros, depending on the car, language and if it requires just sending a simple diagnostic command, or if loading new software to the car is needed. See the pricelist here https://d5t5.com/article/subscription-types-prices
                                          On your car it's loading new software.
                                          If 39 Euros is shown, it's the correct price for your car. Depending on the payment method, additional service charges might be added.
                                          Payment can be done through Vdash. Just buy the required Credits by clicking on the money symbol in the top right corner.
