XC60 chybový kód B00011B
@JarekV740 The code is for a too high resistance between the steering wheel airbag and the SRS module, and has nothing to do with fixing the SRS software. Was the clock spring/SAS replaced together with airbag in the steering wheel? This part usually gets damaged when the airbag is deployed. Also check all connectors between the SRS module and the airbag.
