DIM-U300045 fault
10 Posts 4 Posters 1.0k Views
    jamerico
    Hello to all.
    I just bought a subscription and was wondering if someone can help to solve this dtc. I am new to this program and am not sure if i undrestand the step was done to help another members here. Can someone please guide me through?
    My car is a v40II p3 2014 with engine d4204t14.
    Regards
    José
    • C Offline
      C Offline
      Chłop
      Hello, after reading the errors I also noticed the error DIM-U3000045. What should I do to eliminate it? It seems to me that this error causes the active cruise control to turn off after 1-8 minutes of driving.
      Additionally, I have a question about subscriptions - what does it include? Are things like stage1/stage2 paid extra? Best regards and thank you for any help
        VOLOK
        replied to Chłop on last edited by
        @Chłop said in DIM-U300045 fault:
        DIM-U3000045
        Has the DIM been changed?
        If no, the power supply network is normal. Replace the DIM.
        • C Offline
          C Offline
          Chłop
          No i didnt change nothing, what you mean saying DIM ? You mean odometer, or some part , if yes , maybe do you have some number of that part?? Or maybe you mean some of soft filee???
          Im not a first owner maybe somebody tried to do sth with odometer.
          Thank you for reply and i Hope that i will solve that problem 😉
            jamerico
            Hello again. This dtc appeard after a tuner played around with the milage on the car because he was buying the car to himself. I didn´t notice when i took the car back and when i went to him to put it back original his shop was closed for good and i am not able to speack to him to put it back the original file. I've read some posts that believe that the original software will cure this dtc but i am not sure were to get it. On another thread here there seems to be a solution but i am not sure about the steps to take. Can someone help?
            • C Offline
              C Offline
              Chłop
              Hello, any ideas ;)??
                jamerico
                I was hopping ok2ucx could give a look at my file(like he did with llamas). i have already cloned to the site. When and if he has time. It would be awesome. All i can do is wait.
                J 1 Reply Last reply
                  jd74
                  replied to jamerico on last edited by
                  @jamerico Hey, have you flashed the DIM with the clean DIM software using VDASH? I believe they only look at files to confirm malevolent activity in that file.
                    jamerico
                    Hello. I still haven´t done anything. I read some other post that ok2ucx has corrected another member file and he said that the correction fixed his problem. I am still waiting if ok2ucx can give a look at my file and hopefully fix mine.
                      jamerico
                      I haven´t connected my car to vdash last few days, so i don´t know if it was placed a software update. I even don´t know if it is possible through vdash to do a software upgrade or reload if they had one. I am willing to try anything at this time.
