V50 P1 - Language change + key reprogramming without original key codes
La commande de phares reste la même pour l'allumage automatique. Il y a juste une différence de commodo pour les phares directionnel d'après le manuel d'utilisation...
Il faut le laisser a zero et le capteur se charge du reste . Mais comment l'activer... -
@Mustapha You will need different light switch that looks like this for example
There are 3 different types of this switch.Headlights on in Pos.0 is something different. In some countries it's a legal requirement to drive with headlights on all the time. The configuration for "headlights on in Pos.0" will result in the headlights turn on in all switch positions whenever the engine is running. The light sensor has nothing to do with this. You just won't be able to use the highbeam in Pos. 0 and parking light, and you will drive around with headlights on all the time.
Automatic headlights on/off is meant for cars model year 2011/2012 with Xenons/ABLs and installed daylight running lights, and works by switching the light switch to Pos. "A" in combination with the sunlight sensor. If this works on cars without DRLs and with Halogens is unknown to me.
What options do see when you open "Car configuration" -> "Show old configurator" -> "Lighting" -> "Dipped Beam"
@Mustapha As the complete switching on/off by sunlight sensor is done by the LSM (light switch module) you might just try to find a used switch that has the same buttons and regulators as the current switch plus the "A" positon and install that. There might be no configuration change needed at all. Just another switch.
@Mustapha Automatic headlights is only available from factory for cars which have Xenon/ABL headlights. This automatically means no front fog lights. If your car has halogens and front fog lights, this means no automatic headlights without findung an own solution how to switch the fog lights on/off. Xenon/ABL+front fog lights is not possible with any configuration change/factory parts.
Tu es une vraie bible et je t'en remercie.
Ma foi je vais rester a l'ancienne a allumer a la main
Si j'arrive a trouver une solution pour baisser le bip des radar de recul arrière ça serai génial
Malgré la baisse du volume sur le volant et à la radio ça ne change rien. Même pour moi ça reste super fort le son qui sort de la porte arrière droite .. -
Salut ,
Je viens de voir une annonce d'une v50 en Allemagne. C'est une voiture des pays bas bien configuré . Mais je voulais revenir sur l'allumage des phares auto. La v50 en vente dispose de phares halogènes et d'antibrouillard. Mais avec avec le commodo sans un bouton ...Quen pensez vous ?
@Mustapha That car has Halogens and day light running lights, but no fog lights. So automatic headlights is possible with this configuration. The description from the dealer is wrong. It also doesn't look like it was initially build for the german market. It might have been registered in germany before it was sold to netherland. But the first license plate that car ever had was most probably italian, eastern european or russian, simply because there is literally not a single premium option installed, which is really unusual for german cars.
A close look at the configuration that is stored in the CEM would reveal for which market the car was really build. The price for that car is also, lets say, optimistic. -
https://autohuis24.nl/aanbod/5797512-volvo-v50-2-0-business-pro-edition-navi-leder-trekhaak-nl-auto
Je la trouve quand même bien optionné
Retroviseur rabattable
Téléphone
Régulateur de vitesse
CuirDonc pour toi ce sont des feux de jour . Et si j'achète le commodo sur ovoko et que je l'installe
Il y a un risque de dommages ? Ou c'est sans risques?
Merci -
@Mustapha You are correct. The car has some premium options like leather seats. I must have overlooked that. But it still is a manual. If the clutch, flywheel haven't been replaced yet, you will face a four digit repair bill very soon based on the kilometers on the clock.
As for just changing the switch. That won't work on your current car. There is no switch for front fog lights and automatic halogen headlights. DRLs and the function for automatically turning on halogen headlights was introduced in cars from structure week 2010/44 onwards. Your car is a 2008 and doesn't support that "out of the box". You would need to build your own custom light switch by combining part numbers 31318937 and 30739300 for example. And you also would need to test which CEM configuration would work on your car for this function. And you might also need to add wires from the switch to the CEM as well as relais in the CEM. There is no guarantee that this is possible at all. VIDA and EWD contain allmost all information needed for this kind of retrofit, but it's up to you if you want to spend time and money for trying to get this to work. Comparing wiring diagrams and pin outs of the LSM and CEM from a 2008 and 2012 car would be a good starting point.
Bonjour , je reviens sur lallumage des feux auto.
Pensez vous que je peux juste remplacer l'ampoule et non le bloc antibrouillard complet pour passer en feux de jour ?D'après gemini avec le changement de l'interrupteur et l'activation sur vdash ca devrait aller .
Quelles options s'affichent lorsque vous ouvrez « Configuration du véhicule » -> « Afficher l'ancien configurateur » -> « Éclairage » -> « Feux de croisement » ? Je vais aller voir de suite ce qui s'affiche
