ECM code required or not for Volvo xc70D5 from 2008?
3 Posts 2 Posters 178 Views
    Skara0
    Hello guys,
    I have recently purchased an old xc70 d5 Volvo made in 2008.
    I have the CEM code and I was told that this îs enough, because this old platform does not need the ECM decoded.
    But when logging înto the vdash app, If I am trying to buy one of the available tuning stages, I have a message saying that this îs not possible without the ECM code and even worse, this cannot be decoded in a standard mode:((
    What options do I have, apart from taking out the actual unit to someone who has the right tools to retreive the ECM code?
    Thank you.
      replied to Skara0 on last edited by
      @Skara0 The 185hp Euro4 D5 shouldn't require a pin. This seems to be an error in Vdash asking for a pin. RICA and BSR for example offer tunes without needing a pin for that engine. Only the Euro5 D5s should be pin protected.
        Skara0
        Thank you so much for your answer! I was told that and it was werid when I saw the message in vdash.
        I will contact the vdash support, maybe they can help me with this issue.
