150 Posts 71 Posters 31.8k Views
    replied to ZaanTerror last edited by
    #141
    @ZaanTerror Do you mean 26H1/26H2?
    I have just set up a new laptop with 25H2 and your latest version of VIDA. .NET was installed without needing to download the installer seperately.
      #142
      Yes 26H1 and later the .NET Framework windows feature is no longer included.
        #143
        @ZaanTerror thanks for clarification.
        Info added to the install guides
          volvov70freak
          #144
          How did you diagnose a 2018 ... in the list is only 2015-2016?
            replied to volvov70freak last edited by
            #145
            @volvov70freak after login in to VIDA you first open computer settings in the "Start" tab of VIDA and disable VIN decoding.
            Than you open the "define vehicle profile" menu, check that "VIN decoding off" is written in red next to the VIN box,
            Don't click on the read button!,
            manually enter your VIN,
            select your model,
            select the latest model year available,
            select your engine code, transmission and so on,
            click on ok
            Click on the Diagnostic tab and read your car as usual.
            This only works on some P1s and P3s but not all.
            If your engine isn't listed, you need to select a similar one which uses the same ECM hardware.
            1.5 liter petrol engines and 7-speed automatic are not supported.
            It's also described at the end of the install guides you can find here.
              Vimto1
              Hi, could I get the download link too please? Thanks
                VolvoAugust
                Works like a charm, anybody how can help med with getting Logfiles for diagnotics, need to decode a ECM pin from a edc17cp22?
                  replied to VolvoAugust last edited by
                  #148
                  @VolvoAugust The log file method doesn't work since ages and was only used for the CEM pin. This was also never possible with the offline version of VIDA as this version isn't capable of software downloads at all.
                  The VIDA/Wireshark method also doesn't seem to work for ECM pins. Bench reading is the only option you have. Sorry.
                    Sergiy37103710
                    @ZaanTerror Can you send me the link to sergiy3710@gmail.com
                    • V Online
                      V Online
                      V40
                      Thank you very much for sharing!
