217 Posts 112 Posters 62.7k Views
    replied to Bobeee on last edited by
    #121
    @Bobeee This version of VIDA is heavily modernized "under the hood" to work on 64bit Windows 10/11 only. And running VIDA in a VM is not recommended at all, even if it works. You can create a Windows To Go USB drive or stick with this tool and run VIDA from that, if you want to run a VIDA only environment.
    Everything works exactly the same as all other versions of VIDA2014D. Just the VIN decoder is extended to recognize some P1s and P3s up to modelyear 2019.
    The hardware requirements are slightly higher than for the original VIDA2014D as the SQL server is updated from SQL 2008 to SQL 2025. As well as a lot of other things that are replaced with more modern versions.
    Of course software updates/reloads don't work like all other offline VIDAs.
    The Installer made by ZaanTerror makes it really easy to install if you do a clean install btw.
    Replacing an existing VIDA requires a little effort before you can install the new version.
      jexyq
      #122
      @T5-T6-Schnappi Hi,
      I did a clean install and tried all the steps you suggested. I’m pretty sure the issue was actually on my side - I hadn’t manually filled in the dropdown lists for Transmission, Steering, and Body style.
      I can’t be 100% certain if that was the only problem, because I ran out of patience and installed Windows 7, so I can’t confirm if it would have worked on Windows 10 - but I’m about 90% sure it would have.
      Bit embarrassing how it turned out… anyway, thanks a lot for all your help.
        wrote on last edited by sizan
        #123
        I am having a weird issue on my laptop.(w11) I have installed here, Vida from @ZaanTerror and vdash, latest version.
        if I start vdash, vida monitor crashes.
        if i uninstall net framework 3.5 and then reinstall it, vida works perfectly, until i start Vdash again...
        any toughts ? anyone had the same issue? help ?
          #124
          @sizan This is "normal". The same thing happens with the original VIDA2014D. VIDA will still work as long as VidaMonitor was fully started before it crashes. Just restart your computer after using Vdash to be sure that everything works as expected. The DICE and Mongoose drivers sometimes also get blocked after using Vdash until you reboot.
          Nothing a reboot can't fix or to worry about. 😉
            powerwouz
            Hi, Can you send me the download link please?
            Kind regards,
            Wouter
              Mslacool
                #127
                  #128
                    ButterMackrel
                    Use case:
                    Computer Setup:
                    The OBD Cable:
                      Oskis06
                      Hi!
                      Best regards Oskis!
                        #131
                          tristaoigor
                            Drnemo
                            Thank you ZaarTerror for your exciting work. Im actually installed your VIDA build om my M1 MacBook with ARM Windows 11 on VirtualBox 😃
                            and VIDA work perfectly for me, but I don't used diagnostics tool.
                              ZackAria
                              Hello, Can someone send me a download Link please ?
                                ZackAria
                                @ZaanTerror thanks for the Link 👌
                                  NA
                                  Thanks for the software. If you're using a newer version of windows 11 you may have to manually download the .net framework from here: https://learn.microsoft.com/en-us/dotnet/framework/install/dotnet-35-windows-11
                                    mike99989
                                    link please! 🙂
                                      replied to NA on last edited by
                                      #138
                                      @NA This is usually done automatically by ZaanTerrors installer when .NET 3.5 isn't present on your system while all prerequisites for VIDA are checked and installed. You just have to click on the correct button when the system dialogue to install .NET 3.5 pops up.
                                      See the install guide here
                                        NA is right.
                                        The newest versions of Windows 11 require a seperate installer instead of installing a Windows feature.
                                        I have not implemented this to my installer because the new windows 11 is still in development/testing phase.
                                          pooyork
                                          Thank you so much for all of your work. Would you be so kind to share a link with me? Thank you!
