SPA CEM PIN Decode: 29 keys/s (160 hours) despite stable connection and low ping
17 Posts 5 Posters 2.1k Views
  • A Offline
    A Offline
    alienek
    Some CEM modules (called by our dev "V2") are hard/impossible to decode the standard way. There are other ways to get the cem pin decoded by third-party services (paid of course)
    X T5 T6 SchnappiT 2 Replies Last reply
    • X Offline
      X Offline
      XC90-joch
      replied to alienek on last edited by XC90-joch
      @alienek I know of the third-party services 😜
      But I've already bought the adapter & credits for the D5T5-route, so i expected to get some better results & support. The ticket i submitted @ D5T5 has had the same status for a month now: "Unassigned".
      Pretty lacking for a paid service..
        @alienek if you know which hw-numbers are hard or even impossible to crack, would it be possible to add a warning message to Vdash for those units, so users know that the slow cracking speed or failed/impossible cracking is expected? Do you also know if such problems exist for certain P3 CEMs? My 2018 V60CC took around 130 hours to crack, if I remember correctly, which wasn't a big deal for me. But anyway, knowing that you have to expect much more than usual time for cracking before you even start would be really nice, and will definitely will result in less frustration on the user side. Especially as there are lots of complaints and irritations about vdash regarding cracking and also lack support in general, if you look across popular Volvo forums.
          VOLOK
          If you are willing to wait for a long time to crack the code, you can contact me. Just tell me the VIN and I will crack the password for you within five minutes.
          X H 2 Replies Last reply
          • X Offline
            X Offline
            XC90-joch
            replied to VOLOK on last edited by
            @VOLOK Thanks for the offer, very nice! I have already found another option and now have the CEM-pin. I guess PIN code retrieval by VIN is not possible for the ECM-pin?
            • H Offline
              H Offline
              HoodedLime
              @VOLOK Hi mate. Any chances I could ask you for a help with PIN for my V90? I spent 5 weekends already trying to decode it with Vdash but its absolute joke. 20 keys per second on exactly the same setup that did my P3 in 10hrs at nearly 200 keys per second.
              And sorry for resurrecting an old thread.
              Thanks
                replied to HoodedLime on last edited by
                @HoodedLime Not a helpful answer, I know, but 200 keys/s on a P3 are a clear indicator that your setup is slow or has some sort of bottleneck. 450-500 keys/s on a P3 are possible on good setups. Atleast with P3tool and P3Dx. Not sure about Vdash as I'm not using that for P3 cracking anymore.
                H 1 Reply Last reply
                • H Offline
                  H Offline
                  HoodedLime
                  @T5-T6-Schnappi thanks for the reply. I assume that was due to cheap chinese DICE I was using. But still, 200per/s was light years above my current 20 lol. Anyway, I folded and just ordered myself an Orbit with PIN retrieval so hopefully will get my code very shortly 🙂
                    #15
                    @HoodedLime Good luck! 😉
                    200keys/s is actually okay for a DICE. But on a SPA you should definitely use a Super J2534 or a VOE adapter and not a DICE.
                    • H Offline
                      H Offline
                      HoodedLime
                      #16
                      @T5-T6-Schnappi I actually swapped to enet cable to see but it made no difference to speed. Anyway, received my PIN from Orbit guys 15mins after ordering, outstanding service 🙂
                        #17
                        @HoodedLime I didn't mean for cracking, but for coding/programming your car. The DICE should still work, but is too slow and therefore risky to use.
