Volvo V60 P3 (2016) – Airbag Control Module, Wiring Harness and Programming
1 Posts 1 Posters 7 Views
  • U Offline
    U Offline
    Usturmaca
    I own a 2016 Volvo V60 P3 with the D4204T9 engine.
    I am experiencing problems with the SRS/airbag system. The SRS control module (part number 31429515) has already been repaired, and communication with the module has been restored.
    However, several fault codes remain relating to airbag and seatbelt pretensioner circuits, as well as a low supply voltage fault.
    I am looking for a workshop experienced in Volvo vehicle electronics, VIDA diagnostics, and troubleshooting the complete SRS wiring harness, including connectors and wiring connections.
    Could you please let me know if you can carry out a complete diagnosis and repair of this system?
    Thank you in advance. I look forward to your reply.
    YV1FW79C0G1293851
    V60 2016 D4204T9
    SRS-B00011B Driver Frontal Stage 1 Deployment Control . General Electrical Failures. Circuit resistance above threshold.
    SRS-B00021B Driver Frontal Stage 2 Deployment Control . General Electrical Failures. Circuit resistance above threshold.
    SRS-B00201B Left Side Airbag Deployment Control . General Electrical Failures. Circuit resistance above threshold.
    SRS-B00701B Driver Seatbelt Pretensioner "A" Deployment Control. General Electrical Failures. Circuit resistance above
    threshold.
    SRS-B00751B Second Row Right Seatbelt Pretensioner Deployment Control. General Electrical Failures. Circuit resistance
    above threshold.
    SRS-B00791B Driver Seatbelt Pretensioner "B" Deployment Control. General Electrical Failures. Circuit resistance above
    threshold.
    SRS-B00821B Passenger Seatbelt Load Limiter Deployment Control . General Electrical Failures. Circuit resistance above
    threshold.
    SRS-U300716 Control Module Input Power ""B"". General Electrical Failures. Circuit voltage below threshold.
    ECU HW NUM. SW1 NUM. SW2 NUM. SW3 NUM. SW4 NUM. SERIAL NUM.
    CEM 31412970 31473277 151620156
    DIM 31394183 31453350 259369
    ECM 31452623 32312275 151589
    TCM 31397853 31657369 31397367 151500186
    BCM 31423348 31471025 75208282
    DDM 31376697 31456696 9643996
    PDM 31376699 31456697 9678987
    CCM 31398141 31443711 2001589396
    SAS 31313851 31334561 150616074801
    PSCM 31429806 31451855 152300073781
    SRS 31429515 31451753 11506080207
    PBM 31275180 31381846 31318974 100000642894
    PAC 31381885 31439214 1500545364
    PAM 31423951 31423747 151620265700
    CVM 31318801 31360340 31340742 215061001473
    IHU 31433368 31466587 31466588 31421470 31382708 56150790
