Automatic window clossing with VDD
13 Posts 4 Posters 3.0k Views
    i have excatly the same problem since my dongle was updated to firmware version 95.00, all window commands don't work, before that update everything worked as intended. Vdash also doesn't recognise my door modules since several month while Vida 2014D is communicating normally with them on excactly the same hardware. Third party hardware like two different LAUNCH devices, as well as several android apps through an OBD-Dongle have no problems with adressing the PDM/DDM. It's only Vdash/VDD which doesn't work as intended.
    D 1 Reply Last reply
      D5T5 zub
      hello, can you share VIN, please?
        replied to D5T5 zub on last edited by
        @D5T5-zub YV1FZ40LCJ2053368
        Dongle 1x333
        VIDA now also has troubles communicating with the door modules, so maybe its time to inspect the wiring for me. But there are no DTCs for communication problems nor are there any problems with locks, windows etc...
        As said earlier, everything started when firmware 95.00 was installed on my dongle.
          D5T5 zub
          Hi, I did some investigation related to door module freezing issue
          and now I am testing experimental version.
          Would you like to participate on testing tis version.
            @D5T5-zub yes
              D5T5 zub
              Hi, I have updated your VDD.
              Please plug it out of OBD port and plug back with car started,
              to reload configuration. This update is lock & windows command related.
              So please test those commands and extender options and let me know if any problems.
              Many thanks for cooperation
              Radomir
                D5T5 zub
                I see first attempt - all commands without response -
                are you able to disconnect / connect cars battery
                to reser PDM/DDM, please
                  @D5T5-zub Hello Radomir,
                  today i was able to test the new firmware. I disconnected the battery for around 30 minutes and connect vdash first. The door modules where back online together with 3 DTCs DDM-U014000, PDM-U014000, DDM-U016487. All 3 codes cleared without coming back. Window commands as well as close windows when locking the doors are working just fine. Additionally another bug seems to be fixed. When I locked the car via the button in trunk lid, the VDD app showed the trunk to be still unlocked. This is now fixed also.
                    D5T5 zub
                    thank you for your testing!
                    R.
                      @D5T5-zub I'm experiencing another problem since the update to firmware 0.95.59. My Sensus randomly fails to boot at the first attempt. When I turn on the ignition, I see the boot logo of the Sensus for a longer than usual time, followed by a reboot of the Sensus. This happens maybe 1 of 10 times I start the car and began shortly after the VDD was updated. No DTCs.
