Automatic window clossing with VDD
13 Posts 4 Posters 2.6k Views
    VolvoTallGuy
    Hi there.
    Can anyone tell me why my automatic window clossing by using the VDD stops after a view weeks of working. I can only get it working again by take the fuse out of the DDM. The max is 5 weeks of good working in the last year.
    Thanks.
    D 1 Reply Last reply
    • D5T5 tymonD Offline
      D5T5 tymonD Offline
      D5T5 tymon
      we have the similiar behavior on S60 T6 Polestar 2018, where we try to "catch it", but as you say, it happen occasionaly and therefore it is very hard to find the bug there. It looks like some kind of issue in Volvo DDM/PDM software connected with commands sent from VDD in the "right" time. Can you see any speciffic conditions, before it happen?
        D5T5 zub
        replied to VolvoTallGuy on last edited by
        @VolvoTallGuy - Hi, are you able to find way, how to get car to this state? Any combination of close / lock and extender settings.
          i have excatly the same problem since my dongle was updated to firmware version 95.00, all window commands don't work, before that update everything worked as intended. Vdash also doesn't recognise my door modules since several month while Vida 2014D is communicating normally with them on excactly the same hardware. Third party hardware like two different LAUNCH devices, as well as several android apps through an OBD-Dongle have no problems with adressing the PDM/DDM. It's only Vdash/VDD which doesn't work as intended.
            D5T5 zub
            hello, can you share VIN, please?
              replied to D5T5 zub on last edited by
              @D5T5-zub YV1FZ40LCJ2053368
              Dongle 1x333
              VIDA now also has troubles communicating with the door modules, so maybe its time to inspect the wiring for me. But there are no DTCs for communication problems nor are there any problems with locks, windows etc...
              As said earlier, everything started when firmware 95.00 was installed on my dongle.
                D5T5 zub
                Hi, I did some investigation related to door module freezing issue
                and now I am testing experimental version.
                Would you like to participate on testing tis version.
                  @D5T5-zub yes
                    D5T5 zub
                    Hi, I have updated your VDD.
                    Please plug it out of OBD port and plug back with car started,
                    to reload configuration. This update is lock & windows command related.
                    So please test those commands and extender options and let me know if any problems.
                    Many thanks for cooperation
                    Radomir
                      D5T5 zub
                      I see first attempt - all commands without response -
                      are you able to disconnect / connect cars battery
                      to reser PDM/DDM, please
                        @D5T5-zub Hello Radomir,
                        today i was able to test the new firmware. I disconnected the battery for around 30 minutes and connect vdash first. The door modules where back online together with 3 DTCs DDM-U014000, PDM-U014000, DDM-U016487. All 3 codes cleared without coming back. Window commands as well as close windows when locking the doors are working just fine. Additionally another bug seems to be fixed. When I locked the car via the button in trunk lid, the VDD app showed the trunk to be still unlocked. This is now fixed also.
                          D5T5 zub
                          thank you for your testing!
                          R.
                            @D5T5-zub I'm experiencing another problem since the update to firmware 0.95.59. My Sensus randomly fails to boot at the first attempt. When I turn on the ignition, I see the boot logo of the Sensus for a longer than usual time, followed by a reboot of the Sensus. This happens maybe 1 of 10 times I start the car and began shortly after the VDD was updated. No DTCs.
