Stop-start disable
6 Posts 5 Posters 1.6k Views
    toody
    Hello, after decoding the CEM PIN I wanted to disable the stop/start system in the vehicle by default, but in step 2 the sw doesn't offer me any other option to continue. Do you know where I am making a mistake?
      D5T5 ok2ucx
      Not a mistake on your side.
      Your mild-hybrid engine does NOT support start-stop removal, the "macro" (ready-made configuration) still displays there (and it should not).
        VOLOK
        The MY22 XC90 48V system can turn off the start-stop function
          D5T5 ok2ucx
          Just recently, we have enabled these options for given engine code. You can test yourself, if this setting fails, we will refund.
            PY3SOL
            Sorry to avoid the question but I'm having trouble decoding the CEM PIN of my S60 which is on the P5 hybrid platform just like yours, if you don't mind could you tell me what procedure you performed to decode the PIN password of your car's CEM unit?
              TommyGun
              wrote on last edited by TommyGun
              May I ask what do I need to disable start-stop on XC90 (2018) D5? Do I need to buy something (I already bought adapter). Thanks
