Enable Active High Beam
15 Posts 2 Posters 1.2k Views
    bochenn
    Hello! 👋
    Is it possible to add vía software the Active High Beam system to my car?
    Thanks,
    L
    T5 T6 SchnappiT 3 Replies Last reply
      replied to bochenn on last edited by
      @bochenn if your car has the required hardware like FSM, CVM and so on, than yes.
        @bochenn Does your car have adaptive cruise control and traffic sign recognition?
          replied to bochenn on last edited by T5 T6 Schnappi
          @bochenn AHB.gif here is the schematic of all modules involved for AHB. 7/119 and 7/121 are the height sensor at the front and rear axle.
            bochenn
            Hello @T5-T6-Schnappi and thanks for all the responses and information. But unfortunately I don’t know what comes with my car.
            Can you tell me a way to figure out that?
            I thought with the VIN was enough.
            Thanks again!
            L
              @bochenn The VIN is not enough. It's not fully shown to other users, and even if it was shown in full, it would only be useful for users, who have access to a legit subscription of VIDA which is not possible for private users, except in the USA. You either have to connect the car to Vdash at least once, and then tick the box to add your car configuration when you make a post. Or you simply make a photo of the upper middle black area of your windscreen above the rearview mirror and upload it here. 119578.jpg This area. This photo is for example without the FSM.
              Your car also needs to have Xenon headlights, as cars with Halogens don't have the required height sensors.
                bochenn
                Hey @T5-T6-Schnappi !
                Thanks for the clarification. Let me answer by part:
                1- I just got the mongoose cable to scan my XC60, so I will give a try over the weekend with VDash (if you can point me in the right direction where to look I'll be more than happy).
                2- A while ago I downloaded a sheet with all the features that comes with my car, I'm sharing with you as screenshots some of the lines that mention lights.
                3- Also I'm sharing a photo the upper middle black area of my windscreen. Can't tell if that has FSM or not. Also I can confirm it comes with Xenon HID headlights.
                Thanks,
                Leandro
                95097978-95ba-4652-9eb9-3ed26b9034c5-CleanShot 2026-04-01 at 17.21.04@2x.png
                03e5c909-8f5f-4fed-8b68-e60a043667a7-CleanShot 2026-04-01 at 17.19.43@2x.png
                dc9291c2-8274-46e8-8f73-e6fdf071488f-CleanShot 2026-04-01 at 17.24.03@2x.png
                  bochenn
                  @T5-T6-Schnappi, I forgot to add the photos.
                    @bochenn By the look of your windscreen, I would say your car has the City Safety sensor, collision warning sensor and rain sensor, but no FSM.
                    B 1 Reply Last reply
                      bochenn
                      @T5-T6-Schnappi thanks!
                        @bochenn No problem. That's what this forum is for.
                        For your first steps with Vdash follow this :
                        Install the Super J2534 drivers from here https://d5t5.com/eshop/sw/J2534_Driver_x64.msi
                        Then connect the adapter to the OBD port first, and after that to the computer. Than turn the ignition to pos. II (ignition on, engine not running) by pressing the start/stop button for maybe 3-5 seconds, but without your foot on the brake pedal. Than start Vdash. Log in to your account and press connect in the top left corner.
                        You should see all modules that are installed in your car after that.
                        Don't buy any subscription or configuration changes until you haven't cracked your CEM pin.
                        And no tunes until your ECM pin isn't cracked.
                        If you have any questions, just ask. 😉
                          bochenn
                          Hey @T5-T6-Schnappi, first and foremost thanks for all the help!
                          BTW this link gives a 404 error https://d5t5.com/eshop/sw/J2534_Driver_x64.msi.
                          Yesterday I connected my XC60 to VIDA and learned that Active High Beam is on the car but apparently is not working.
                          I'm attaching a fault trace that I managed to get and the whole Vehicle details.
                          I understand this might be out of scope of VDASH so if you can't help me is ok, at least point me on some direction to get this fixed.
                          L
                          xc60_page-0001.jpg xc60_page-0002.jpg xc60_page-0003.jpg xc60_page-0004.jpg AHB diagnostics.png
                            @bochenn The link has been changed to https://d5t5.com/sw/J2534_Driver_x64.msi
                            Check the connector at the headlight for corrosion. Also check for humidity inside the headlight. Remove the headlight and gently unplug and plug in the connector 2-3 times. It's also possible that your headlight is broken and needs replacement. Sadly this is quite common.
                              bochenn
                              @T5-T6-Schnappi thanks! I'll look into it. Humidity I can confirm it doesn't have, I will check later if there is corrosion in the connector.
                              I compared my menu (in spanish) vs. the one I found online (in english) on some youtube videos and I don't have the setting to enable/disable the AHB. Also like the DRL, but mine are working correctly, maybe some settings are by default? All of this confuses me.
                              L
                                #15
                                @bochenn after looking over your configuration I'm almost 100% sure that your car doesn't have a FSM and therefor no AHB. You don't have collision warning, traffic sign indication, lane keeping or adaptive cruise control which is a clear sign of "no FSM".
                                Do you see your headlights leveling themself when you turn them on? Maybe park in front of a wall and take a closer look. You should see the light going up and down right after you turn them on. If not, the leveling is not working which means new (used) headlights. The same goes for the bending light function. Turn the steering wheel and see if the light follows. You can also activate these functions in VIDA (Diagnostic/Vehicle communication/CEM/Activations) to test it. Also check fuse nr. 16
