V40 2013 DIM-U300045 DTCS
24 Posts 5 Posters 8.7k Views
    CristianMD
    replied to David D5T5 dev on last edited by
    #21
    @David-D5T5-dev said in V40 2013 DIM-U300045 DTCS:
    Hi, we have prepared automatic fixup for these manipulated milages. Just connect your car in Vdash and after the car ecus are loaded, it should appear in the "available software" part of Vdash.
    hi,
    for this operation we need cem pin decode ?
    thanks.
      joroartcorp
      Hi, just to tell you that I have made the SW Fix update and nothing happened. Still receiving the DTC and mileage still the same. Refund is not possible, so I don’t know what to do now.
        joroartcorp
        alt text
        BTW this is what my mileage shows. I dont know if it will help for the problem solving and the correct fix to be applied, as the one for the DIM didnt worked.
        Thanks in advance!
        • David D5T5 devD Offline
          David D5T5 dev
          replied to VladGB on last edited by
          #24
          @VladGB If you don't see it on the main page, it can take few minutes to appear. Or you can wait for a new Vdash release which will be done this friday and go to "advanced" section for the fix.
