CEM PIN in Vdash
3 Posts 2 Posters 805 Views
    joroartcorp
    Hi all,
    I have finished the decoding of my V40, but where can I find the CEM PIN if I need to use it further?
    I have seen that if I use the AI option, it will be faster, but the Vdash team will keep the PIN for themselves, but if I use the standard "slow" method, the PIN should be provided.
    Is there anywhere I can find the PIN, or my understanding is wrong?
    Thank You!
      replied to joroartcorp on last edited by
      @joroartcorp Vdash\D5T5 won't show you the PIN. No matter what decode method you use. The PIN is added to the vdash database once it's decoded, so you can work with vdash. If you need the PIN for other programs, you need to find other ways to retrieve it.
        joroartcorp
        This is what I thought as well. Thank you for the confirmation! 🙂
