Xc70 dead after Decoding PIN with vdash
3 Posts 3 Posters 935 Views
  • G Offline
    G Offline
    Gabe1987
    Hi there people!
    I’ll be short… last night I plugged my super j2534 on to my volvo xc70 2007 to decode the (cem?) PIN.
    After 8h or so.. I received an email from d5t5 saying that the decoding of my VIN has been done. Even the Vidash said that everything was completed OK.
    Then I go to switch on the key and nothing.
    Literally nothing works, no lights on the screen, just complete death.
    (The car was plugged on to a battery charger.)
    What could have happened?
    I read something about the cem being “bricked”. Im lost.
    Thanks for your help!
      joroartcorp
      Have you tried to unplug the battery for few minutes and try start the car again? Also is your charger showing the voltage, or did you seen in Vdash what was the voltage during the process?
        radoslaw317
        What caind of battery support unit you use?. If you use bad battery charger you may dammage you battery or even worst baked your BCM.
        Just check if the battery still holding power
