SRS
3 Posts 3 Posters 690 Views
    RickLongVoc
    Hi
    Errors in Malfunctioning SRS System
    Code Description
    CEM-B10A202 Input failure. General signal failure.
    CEM-B10A206 Data input failure. General failure information. Failures related to algorithms.
    CEM-B10A215 Data input failure. General electrical faults. Short circuit to battery or open circuit.
    CEM-B113C15 Emergency switch indication. General electrical equipment faults. Short circuit to ground or open circuit.
    CEM-U015100 Lost communication with supplemental restraint system (SRS). General failure information. Subtype information not available.
    CEM-U016400 Lost communication with climate control unit. General failure information. Subtype information not available.
    CEM-U023200 Lost communication with left side object detection module (SODL). General failure information. Subtype information not available.
    CEM-U023300 Lost communication with right side object detection module (SODR). General failure information. Subtype information not available.
    CEM-U030141 Software incompatibility with ECM/PCM. Internal system failures. General checksum failure.
    CEM-U040086 Incorrect data received. Bus/message signal failure. Incorrect signal.
    CEM-U101E00 Lost communication with parking assist camera (PAC). General failure information. Subtype information not available.
    DIM-U015100 Lost communication with supplemental restraint system module. General failure information. Subtype information not available.
    BCM-U015100 Lost communication with supplemental restraint system (SRS).
    BCM-U002855 Programming failures in Vehicle Communication Bus A system. Not configured.
    DDM-B118E00 Left front window. General failure information. Subtype information not available.
    DDM-B119000 Left rear window. General failure information. Subtype information not available.
    PDM-B118F00 Right front window. General failure information. Subtype information not available.
    PDM-B119100 Right rear window. General failure information. Subtype information not available.
    CCM-B10884A LIN B bus. Internal system failures. Unsuitable component installed.
    PBM-U015100 Lost communication with supplemental restraint system module. General failure information. Subtype information not available.
    FSM-U015100 Lost communication with supplemental restraint system module. General failure information. Subtype information not available.
    FSM-U040168 Incorrect data received from engine control module. Algorithm failures. Event information.
    FSM-U041568 Incorrect data received from brake control module. Algorithm failures. Event information.
    SODL-U014000 Lost communication with central electronic module. General failure information. Subtype information not available.
    SODL-U016400 Lost communication with climate control module (MCU). General failure information. Subtype information not available.
    SODL-U041868 Incorrect data received from brake control module (BCM). Algorithm failures. Event information.
    SODR-U014000 Lost communication with central electronic module. General failure information. Subtype information not available.
    SODR-U016400 Lost communication with climate control module (MCU). General failure information. Subtype information not available.
    SODR-U041868 Incorrect data received from brake control module (BCM). Algorithm failures. Event information.
    PAC-U010187 Lost communication with transmission control module (TCM). Bus signal/message transmission failures. Message missing.
    PAC-U012187 Lost communication
      When exactly did those errors occur? The massive amount of communication errors looks like a voltage problem. Or did you try to perform a configuration change while the engine was running?
        Volvo Fier
        Hello i have problem with srs
        Volvo xc60 2013
        Code: B00B513, B00C513, U015400, U300716
