213 Posts 109 Posters 60.4k Views
    wrote on last edited by sizan
    #123
    I am having a weird issue on my laptop.(w11) I have installed here, Vida from @ZaanTerror and vdash, latest version.
    if I start vdash, vida monitor crashes.
    if i uninstall net framework 3.5 and then reinstall it, vida works perfectly, until i start Vdash again...
    any toughts ? anyone had the same issue? help ?
      #124
      @sizan This is "normal". The same thing happens with the original VIDA2014D. VIDA will still work as long as VidaMonitor was fully started before it crashes. Just restart your computer after using Vdash to be sure that everything works as expected. The DICE and Mongoose drivers sometimes also get blocked after using Vdash until you reboot.
      Nothing a reboot can't fix or to worry about. 😉
        powerwouz
        Hi, Can you send me the download link please?
        Kind regards,
        Wouter
          Mslacool
            #127
              #128
                ButterMackrel
                Use case:
                Computer Setup:
                The OBD Cable:
                  Oskis06
                  Hi!
                  Best regards Oskis!
                    #131
                      tristaoigor
                        Drnemo
                        Thank you ZaarTerror for your exciting work. Im actually installed your VIDA build om my M1 MacBook with ARM Windows 11 on VirtualBox 😃
                        and VIDA work perfectly for me, but I don't used diagnostics tool.
                          ZackAria
                          Hello, Can someone send me a download Link please ?
                            ZackAria
                            @ZaanTerror thanks for the Link 👌
                              NA
                              Thanks for the software. If you're using a newer version of windows 11 you may have to manually download the .net framework from here: https://learn.microsoft.com/en-us/dotnet/framework/install/dotnet-35-windows-11
                                mike99989
                                link please! 🙂
                                  replied to NA on last edited by
                                  #138
                                  @NA This is usually done automatically by ZaanTerrors installer when .NET 3.5 isn't present on your system while all prerequisites for VIDA are checked and installed. You just have to click on the correct button when the system dialogue to install .NET 3.5 pops up.
                                  See the install guide here
                                    NA is right.
                                    The newest versions of Windows 11 require a seperate installer instead of installing a Windows feature.
                                    I have not implemented this to my installer because the new windows 11 is still in development/testing phase.
                                      pooyork
                                      Thank you so much for all of your work. Would you be so kind to share a link with me? Thank you!
                                        #141
                                        @ZaanTerror Do you mean 26H1/26H2?
                                        I have just set up a new laptop with 25H2 and your latest version of VIDA. .NET was installed without needing to download the installer seperately.
                                          #142
                                          Yes 26H1 and later the .NET Framework windows feature is no longer included.
