264 Posts 141 Posters 74.8k Views
    #127
      #128
        ButterMackrel
        Use case:
        Computer Setup:
        The OBD Cable:
          Oskis06
          Hi!
          Best regards Oskis!
            #131
              tristaoigor
                Drnemo
                Thank you ZaarTerror for your exciting work. Im actually installed your VIDA build om my M1 MacBook with ARM Windows 11 on VirtualBox 😃
                and VIDA work perfectly for me, but I don't used diagnostics tool.
                  ZackAria
                  Hello, Can someone send me a download Link please ?
                    ZackAria
                    @ZaanTerror thanks for the Link 👌
                      NA
                      Thanks for the software. If you're using a newer version of windows 11 you may have to manually download the .net framework from here: https://learn.microsoft.com/en-us/dotnet/framework/install/dotnet-35-windows-11
                        mike99989
                        link please! 🙂
                          replied to NA on last edited by
                          #138
                          @NA This is usually done automatically by ZaanTerrors installer when .NET 3.5 isn't present on your system while all prerequisites for VIDA are checked and installed. You just have to click on the correct button when the system dialogue to install .NET 3.5 pops up.
                          See the install guide here
                            NA is right.
                            The newest versions of Windows 11 require a seperate installer instead of installing a Windows feature.
                            I have not implemented this to my installer because the new windows 11 is still in development/testing phase.
                              pooyork
                              Thank you so much for all of your work. Would you be so kind to share a link with me? Thank you!
                                #141
                                @ZaanTerror Do you mean 26H1/26H2?
                                I have just set up a new laptop with 25H2 and your latest version of VIDA. .NET was installed without needing to download the installer seperately.
                                  #142
                                  Yes 26H1 and later the .NET Framework windows feature is no longer included.
                                    #143
                                    @ZaanTerror thanks for clarification.
                                    Info added to the install guides
                                      volvov70freak
                                      #144
                                      How did you diagnose a 2018 ... in the list is only 2015-2016?
                                        replied to volvov70freak on last edited by
                                        #145
                                        @volvov70freak after login in to VIDA you first open computer settings in the "Start" tab of VIDA and disable VIN decoding.
                                        Than you open the "define vehicle profile" menu, check that "VIN decoding off" is written in red next to the VIN box,
                                        Don't click on the read button!,
                                        manually enter your VIN,
                                        select your model,
                                        select the latest model year available,
                                        select your engine code, transmission and so on,
                                        click on ok
                                        Click on the Diagnostic tab and read your car as usual.
                                        This only works on some P1s and P3s but not all.
                                        If your engine isn't listed, you need to select a similar one which uses the same ECM hardware.
                                        1.5 liter petrol engines and 7-speed automatic are not supported.
                                        It's also described at the end of the install guides you can find here.
                                          Vimto1
                                          Hi, could I get the download link too please? Thanks
                                          • 13
                                          • 14
