264 Posts 141 Posters 74.8k Views
    powerwouz
    Hi, Can you send me the download link please?
    Kind regards,
    Wouter
      Mslacool
        #127
          #128
            ButterMackrel
            Use case:
            Computer Setup:
            The OBD Cable:
              Oskis06
              Hi!
              Best regards Oskis!
                #131
                  tristaoigor
                    Drnemo
                    Thank you ZaarTerror for your exciting work. Im actually installed your VIDA build om my M1 MacBook with ARM Windows 11 on VirtualBox 😃
                    and VIDA work perfectly for me, but I don't used diagnostics tool.
                      ZackAria
                      Hello, Can someone send me a download Link please ?
                        ZackAria
                        @ZaanTerror thanks for the Link 👌
                          NA
                          Thanks for the software. If you're using a newer version of windows 11 you may have to manually download the .net framework from here: https://learn.microsoft.com/en-us/dotnet/framework/install/dotnet-35-windows-11
                            mike99989
                            link please! 🙂
                              replied to NA on last edited by
                              #138
                              @NA This is usually done automatically by ZaanTerrors installer when .NET 3.5 isn't present on your system while all prerequisites for VIDA are checked and installed. You just have to click on the correct button when the system dialogue to install .NET 3.5 pops up.
                              See the install guide here
                                NA is right.
                                The newest versions of Windows 11 require a seperate installer instead of installing a Windows feature.
                                I have not implemented this to my installer because the new windows 11 is still in development/testing phase.
                                  pooyork
                                  Thank you so much for all of your work. Would you be so kind to share a link with me? Thank you!
                                    #141
                                    @ZaanTerror Do you mean 26H1/26H2?
                                    I have just set up a new laptop with 25H2 and your latest version of VIDA. .NET was installed without needing to download the installer seperately.
                                      #142
                                      Yes 26H1 and later the .NET Framework windows feature is no longer included.
                                        #143
                                        @ZaanTerror thanks for clarification.
                                        Info added to the install guides
                                          volvov70freak
                                          #144
                                          How did you diagnose a 2018 ... in the list is only 2015-2016?
                                          • 13
                                          • 14
