immobilizer off
7 Posts 3 Posters 3.3k Views
    Mir 21
    Hi
    Have sponserd account,how to go to make immobilizer off.
    have contact with car via duice and i can read car with vdash.
    Step by step please from cost to how to,I am new with Vdash.
      replied to Mir 21 on last edited by
      This post is deleted!
        @Mir-21 there is no way to disable or circumvent the immobilizer with vdash.
        If all keyfobs for the car are missing, you can decode the CEM pin and IMMO pin and simply add new fobs to the car. (except keyless ones).
        If the existing fobs don't work anymore, you need to replace the immobilizer antenna. Here https://parts.volvocarsofmarietta.com/a/Volvo_2010_V70-32l-6-cylinder/_51513_5697318/Ignition-switch/GR-366172.html?assemblySearchGuid=98B8BC63-0131-492B-97AC-D9261C5D2F42 you can find the part numbers.
        If your car was involved in an accident, your car is in“ crash mode“ and won't start. In this case you have to replace all airbags that were deployed, and than you can use vdash to get your car back to live.
          Mir 21
          Thank you T5 T6 Schnappi.
          In vida I get all parameter ok exept 2 which I think its the problem,
          ECM -control module voltage ........................................0.11 V
          ECM-battery voltage......................................................0.06 V
          are these normal?or its because of immobilizer on?
          thank you again
            Hi, In Vida go to the “information” heading at the top, then “Product specification”, the “Specifications Other” then any module you care to expand has “Description of Parameters”. There you can see the parameter ranges and define if the values you are receiving are within, or out of range.
              @Mir-21 both voltages should show something around 12V when the ignition is on. Check all fuses and also the connectors and grounds of the ECM, CEM, SRS. Maybe something became lose in the event of the crash.
                Mir 21
                Thank you very much, will do as you say.
