V40 2013 DIM-U300045 DTCS
23 Posts 5 Posters 880 Views
    Hi and thanks for the reply! Created a ticket, so now waiting to see if there will be response from the VDASH team.
      VladGB
      Hi,
      I have the same issue but I just want to get rid of the DTC because my Adaptive cruise control is not working because of it. I have the TFT module as stock.
      S80 T6 AWD 2014.
        I also want to get rig of the DTC, but it seems that without removing the manipulated software and installing the correct one, this will not happen.
          replied to VladGB on last edited by
          @VladGB ACC not working has nothing to do with this DTC. There must be some other DTC in your car for this. Most probably your FSM is misaligned and there should also be a DTC present for this.
            VladGB
            Hi,
            I have FSM-U042368 too. How to fix this then?
              @VladGB I have newer seen this code before. This code means no communication towards the DIM and has no fault trace in VIDA, except check the DIM. And it is the cause for ACC not working.
              Did you do any retrofits and/or configuration changes with vdash or P3tool?
                VladGB
                No modifications, just the previous owner has manipulated the milage.
                  #15
                  @VladGB in this case you have the choice to visit a volvo garage and perform a software reload via an official VIDA subscription for the DIM. Or you have to create a support ticket and ask for help from the vdash devs. But you might need to crack your CEM pin to perform a software reload via vdash.
                  • David D5T5 devD Offline
                    David D5T5 dev
                    Hi, we have prepared automatic fixup for these manipulated milages. Just connect your car in Vdash and after the car ecus are loaded, it should appear in the "available software" part of Vdash.
                    V C 2 Replies Last reply
                    2
                      Hi David, is this a fix which will just clear the DTC, or also will restore the original mileage?
                        replied to joroartcorp last edited by
                        @joroartcorp this should restore the original factory software of the DIM, so correct milage and no DTC.
                          VladGB
                          replied to David D5T5 dev last edited by
                          #19
                          @David-D5T5-dev
                          Hi,
                          I can’t seem to find this available software.
                          Can you explain please how to load it in vdash?
                            Probably this is only for V40, or bonded with my VIN, I cant tell. It cost 39EUR + 20%VAT, so Im going to wait a bit till I install it.
                            • C Offline
                              C Offline
                              CristianMD
                              #21
                              @David-D5T5-dev said in V40 2013 DIM-U300045 DTCS:
                              hi,
                              for this operation we need cem pin decode ?
                              thanks.
                                Hi, just to tell you that I have made the SW Fix update and nothing happened. Still receiving the DTC and mileage still the same. Refund is not possible, so I don’t know what to do now.
                                  alt text
                                  BTW this is what my mileage shows. I dont know if it will help for the problem solving and the correct fix to be applied, as the one for the DIM didnt worked.
                                  Thanks in advance!
