Vdash Live Data
15 Posts 4 Posters 95 Views
    spoonVolvo
    Every time when trying to live data the program freezes. Does live data work at all?
      Do you receive the “Frontend bit responding…” error?
        spoonVolvo
        I dont receive anything error. When I tried to live data the program freezes and I can't do anything.
          spoonVolvo
          Program freezes in windows 8 and windows 11 the same
            replied to spoonVolvo last edited by
            @spoonVolvo what adapter do you use? DICE, Mongoose, Super J2534....?
              spoonVolvo
              I use J2534
              https://pl.aliexpress.com/item/1005005100424102.html?spm=a2g0o.order_list.order_list_main.17.3cc21c24dWXLVp&gatewayAdapt=glo2pol
                @spoonVolvo can't follow your link "This Item is not available in your region"
                What name does Vdash show in the top right corner, when connected to the car? 46159.jpg
                  spoonVolvo
                    @spoonVolvo this adapter "should" work. At which exact point is vdash freezing? When you hit the diagnostic button or after you selected parameters? Vdash shows lots of parameters that aren't actually supported by the car it's connected to.
                    Did you create an exception for the (hidden) vdash directory (C:\Users{your user name}\AppData\Local\VDASH) in your antivirus? Some AV software like AVG, Avast, Norton heavily interfere with Vdash.
                      Vulpes
                      I am having the same issue, however I have noticed that not all parameters freeze the program when selected.
                      In my case VDash freezes whenever I select specific parameters and then click "start".
                        spoonVolvo
                        Vdash freezes whenever i selected parameters and clik "Start"
                        I dont have antivirus
                          spoonVolvo
                            spoonVolvo
                            I record video mp4 but when i have add I receives message:" You do not have enough privileges for this action"
                              spoonVolvo
                              https://streamable.com/gg3fey
                                spoonVolvo
                                https://streamable.com/e2cv34
                                https://streamable.com/fejuxy
