Vdash Live Data
24 Posts 6 Posters 7.5k Views
    spoonVolvo
    I dont receive anything error. When I tried to live data the program freezes and I can't do anything.
      spoonVolvo
      Program freezes in windows 8 and windows 11 the same
        replied to spoonVolvo on last edited by
        @spoonVolvo what adapter do you use? DICE, Mongoose, Super J2534....?
          spoonVolvo
          I use J2534
          https://pl.aliexpress.com/item/1005005100424102.html?spm=a2g0o.order_list.order_list_main.17.3cc21c24dWXLVp&gatewayAdapt=glo2pol
            @spoonVolvo can't follow your link "This Item is not available in your region"
            What name does Vdash show in the top right corner, when connected to the car? 46159.jpg
              spoonVolvo
                @spoonVolvo this adapter "should" work. At which exact point is vdash freezing? When you hit the diagnostic button or after you selected parameters? Vdash shows lots of parameters that aren't actually supported by the car it's connected to.
                Did you create an exception for the (hidden) vdash directory (C:\Users{your user name}\AppData\Local\VDASH) in your antivirus? Some AV software like AVG, Avast, Norton heavily interfere with Vdash.
                  Vulpes
                  I am having the same issue, however I have noticed that not all parameters freeze the program when selected.
                  In my case VDash freezes whenever I select specific parameters and then click "start".
                    spoonVolvo
                    Vdash freezes whenever i selected parameters and clik "Start"
                    I dont have antivirus
                      spoonVolvo
                        spoonVolvo
                        I record video mp4 but when i have add I receives message:" You do not have enough privileges for this action"
                          spoonVolvo
                          https://streamable.com/gg3fey
                            spoonVolvo
                            https://streamable.com/e2cv34
                            https://streamable.com/fejuxy
                              Szabla
                              Same here. Noticed the freezing problem trying to read MAP of MAF data.
                                spoonVolvo
                                The program freezes regardless of the PID parameter I choose. Seeing that I'm not the only one having these problems, I conclude that the program simply isn't working.
                                  spoonVolvo
                                  After update, program not recognizes modules
                                    spoonVolvo
                                    Before
                                      spoonVolvo
                                      After
                                        spoonVolvo
                                        Great comic.
                                        https://d5t5.com/comics/gustarssons-comicsoon/11/pl
                                        It would be nice if it live data worked 🙂 🙂
                                        • David D5T5 devD Offline
                                          David D5T5 dev
                                          Hi guys, Vdash dev here. Sorry for the issue with live data freezing. I think I have it fixed in the version which will be coming in February.
