Volvo S60 2014
3 Posts 2 Posters 20 Views
  • S Online
    S Online
    Hi.
    I have this Volvo S60 D4 ( 2014 ), and when I tested it with DiCE, i have this error:
    CEM-U030141 - Software incompatibility with ECM/PCM - Sistem internal failures - General CheckSum Failure.
    any ideea guys, how can it be fixed?
    10x a lot !
      This indicates that your car has a tuning or modified software installed on the ECM. Most probably a so called EGR delete as your car is a diesel. Some info here: https://d5t5.com/article/zname-dtc-po-uprave-vykonu You can visit an official volvo dealer and ask for a software reload for the ECM with VIDA to revert to the original software, but I can't recommend this, as you will have lots of other problems afterwards,because there are most probably have been done some more modifications to your car. For example a blanking plate for the EGR, or maybe even the DPF is removed.
      • S Online
        S Online
        No, the DPF is not removed ( checked ) and the EGR and the cooler we're changed at a volvo dealer in Sweden as the volvo dealer showed me on the computer and i have the operations mentioned on the car book.
        interesting info about the blanking plate for the egr, i will check 🙂
        One more question : it seems that i have some problems with the fact that the air is not venting corect and as before. So, no error about the CCM whatsoever, but if I try to calibrate the damper motors, looks like it is done all ok, but the values are all wrong. ( ex : recirculation motor preset range 810 steps, actual range 3075 steps ) and so.
        Is it possibile that vida will not show the ccm errors cause that ECM issue? maybe I am missing some other errors about the car..
