SRS Coding
26 Posts 3 Posters 1.5k Views
    radoslaw317
    Hi everyone.
    I have a question, can i code SRS used SRS u it to my XC60 2013 using VDASH or they dont offer software download.
    Is there only the way to do is a VIDA online ?
      radoslaw317
      I bought from vdash srs configuration 99€ and it does nothing wasted the money i messange them but looks like they don care no reply.
      • David D5T5 devD Online
        David D5T5 dev
        wrote on last edited by David D5T5 dev
        Hi, I've checked and looks like there's communication fault with the SRS. We are checking it now. Can you please send me your ticket ID?
        R 1 Reply Last reply
          David D5T5 dev
          Also can you please connect the car in some near future so we have fresh data?
          • 2 Offline
            2 Offline
            2009 S80 T6 Owner
            Hi everyone, I was wondering if the following are the correct steps to use "Configure SRS" to code a new/used module (part no. 31264861 or 31288291) to work with my 2009 S80 T6?
            1. Install the new/used module,
            2. In VDASH, click on the SRS module to bring up the "Supplementary Restraint System" dialog, click "Configure SRS".
            Thanks.
            R 2 Replies Last reply
              radoslaw317
              replied to David D5T5 dev on last edited by
              @D5T5-David Hi David.
              thank you for your replay i just seen your text i though you guys dont going to reply, can you tell me when i can find ticket ID please.
              • 2 Offline
                2 Offline
                2009 S80 T6 Owner
                Hi @D5T5-David,
                I was reading the "Preconfiguration" section of the SRS configuration page (https://d5t5.com/article/srs-config) and wonder what is involved in "cloning firmware".
                The micro-controller inside my SRS module has a 4KB EEPROM and 256KB flash. I learned when the 256KB flash of the donor unit has been overwritten (with the content from another unit,) the module loses communication (module not found in VDASH.)
                In my case, both the EEPROM and flash of the donor unit were overwritten with the content of my original unit and the donor unit lost communication afterwards.
                Your kind help will be much appreciated!
                Albert
                  radoslaw317
                  solved my problem, after i repaired all deployed airbags i did crash reset by CG100X and i get crash date and ABS fault so i make worst, didn't notice that i messed up with ABS as well i thought ABS was replaced without coding before i bought this vehicle from the auction.
                  so, after many days of fighting with this vehicle i removed SRS module and restore eeprom to previous settings with crash date and then run crash date with vdash again and then bang all sorted all faults gone ABS and SRS back to normal.
                    radoslaw317
                    replied to 2009 S80 T6 Owner on last edited by
                    @2009-S80-T6-Owner
                    Hi there configuration is not a coding you need to clone your used SRS
                      radoslaw317
                      @2009-S80-T6-Owner
                      all so its highly recommend using same module as original one same part number or it want work you are cloning only to the same part number unit.
                      • 2 Offline
                        2 Offline
                        2009 S80 T6 Owner
                        Thanks @radoslaw317 for your reply and congratulations on resolving your Volvo electronic issues!
                        Per your recommendation, I will get a used module with the same Volvo part number as my original SRS module for replacement.
                        I was carefully reading your detailed post (from 17 hours ago.) Am I right in understanding below was what you did to fix the SRS issue:
                        1. Removed the donor SRS module from the car and restored the EEPROM content to its original state (which includes the previous crash date).
                        2. Use VDASH to configure the donor SRS module to work with your car.
                        Many thanks!
                          radoslaw317
                          @2009-S80-T6-Owner
                          If you have original srs unit with crash date leve in the car plug in obd scanner and go to BCM and restore crash date than connect Vdash and go to srs module and choose crash date reset then run the process and it should work
                          • 2 Offline
                            2 Offline
                            2009 S80 T6 Owner
                            Thanks @radoslaw317.
                            My original SRS module is showing the SRS-U300000 (internal communications error) which indicates a hardware problem although my car was never involved in any accident. That's why I inquired about how to make a donor module work with my car using VDASH.
                            Thanks again.
                              radoslaw317
                              ok so that's change everything. with U300000 you want to be able to clone your original SRS it must be done on the bench. what is your original part number
                              • 2 Offline
                                2 Offline
                                2009 S80 T6 Owner
                                Below are the details for my original SRS module-
                                Part number: 31264861
                                Serial number: 008101000245
                                TEMIC barcode: FBV8K10A7L
                                Donor module details-
                                Serial number: 007112500211
                                TEMIC barcode: FBV7L25A6J
                                Both the serial number and the TEMIC barcode are in the EEPROM.
                                I have a programmer that can read the 4KB EEPROM of the MC9S12XDT256VAL micro-controller inside.
                                Advice welcomed (i.e. which part of the original module EEPROM content should be cloned into the donor module EEPROM...etc.)
                                  radoslaw317
                                  you need to clone whole of the data from original unit ( MC9S12XDT256VAL ) to the donor,
                                  make sure you erase donor 16 Bit Microcontroller ( MC9S12XDT256VAL ) before writing original data
                                  • 2 Offline
                                    2 Offline
                                    2009 S80 T6 Owner
                                    1. Erase donor module EEPROM
                                    2. Write the EEPROM content of the original module to the donor module EEPROM
                                    Let me give that a try. Thanks muchly!
                                      radoslaw317
                                      @2009-S80-T6-Owner
                                      Thats correct.
                                      May i know what type of tool you using?
                                      • 2 Offline
                                        2 Offline
                                        2009 S80 T6 Owner
                                        @radoslaw317, I use a UPA-USB programmer.
                                          radoslaw317
                                          UPA-USB programmer is a worthing to get?
                                          I have CG100X but it won't work with Volvo 100% crash date I clear in Volvo cars make wors then was I have one Volvo xc60 to clone srs but i can't find any good programmer
                                          can you check if UPA can clone
                                          Volvo P/N P31406637
                                          Bosch P/N 0 285 012 268
                                          thank you
