SRS Coding
26 Posts 3 Posters 14.2k Views
    radoslaw317
    replied to David D5T5 dev on last edited by
    @D5T5-David Hi David.
    thank you for your replay i just seen your text i though you guys dont going to reply, can you tell me when i can find ticket ID please.
    • 2 Offline
      2 Offline
      2009 S80 T6 Owner
      Hi @D5T5-David,
      I was reading the "Preconfiguration" section of the SRS configuration page (https://d5t5.com/article/srs-config) and wonder what is involved in "cloning firmware".
      The micro-controller inside my SRS module has a 4KB EEPROM and 256KB flash. I learned when the 256KB flash of the donor unit has been overwritten (with the content from another unit,) the module loses communication (module not found in VDASH.)
      In my case, both the EEPROM and flash of the donor unit were overwritten with the content of my original unit and the donor unit lost communication afterwards.
      Your kind help will be much appreciated!
      Albert
        radoslaw317
        solved my problem, after i repaired all deployed airbags i did crash reset by CG100X and i get crash date and ABS fault so i make worst, didn't notice that i messed up with ABS as well i thought ABS was replaced without coding before i bought this vehicle from the auction.
        so, after many days of fighting with this vehicle i removed SRS module and restore eeprom to previous settings with crash date and then run crash date with vdash again and then bang all sorted all faults gone ABS and SRS back to normal.
          radoslaw317
          replied to 2009 S80 T6 Owner on last edited by
          @2009-S80-T6-Owner
          Hi there configuration is not a coding you need to clone your used SRS
            radoslaw317
            @2009-S80-T6-Owner
            all so its highly recommend using same module as original one same part number or it want work you are cloning only to the same part number unit.
            • 2 Offline
              2 Offline
              2009 S80 T6 Owner
              Thanks @radoslaw317 for your reply and congratulations on resolving your Volvo electronic issues!
              Per your recommendation, I will get a used module with the same Volvo part number as my original SRS module for replacement.
              I was carefully reading your detailed post (from 17 hours ago.) Am I right in understanding below was what you did to fix the SRS issue:
              1. Removed the donor SRS module from the car and restored the EEPROM content to its original state (which includes the previous crash date).
              2. Use VDASH to configure the donor SRS module to work with your car.
              Many thanks!
              R 1 Reply Last reply
                radoslaw317
                @2009-S80-T6-Owner
                If you have original srs unit with crash date leve in the car plug in obd scanner and go to BCM and restore crash date than connect Vdash and go to srs module and choose crash date reset then run the process and it should work
                • 2 Offline
                  2 Offline
                  2009 S80 T6 Owner
                  Thanks @radoslaw317.
                  My original SRS module is showing the SRS-U300000 (internal communications error) which indicates a hardware problem although my car was never involved in any accident. That's why I inquired about how to make a donor module work with my car using VDASH.
                  Thanks again.
                    radoslaw317
                    ok so that's change everything. with U300000 you want to be able to clone your original SRS it must be done on the bench. what is your original part number
                    • 2 Offline
                      2 Offline
                      2009 S80 T6 Owner
                      Below are the details for my original SRS module-
                      Part number: 31264861
                      Serial number: 008101000245
                      TEMIC barcode: FBV8K10A7L
                      Donor module details-
                      Serial number: 007112500211
                      TEMIC barcode: FBV7L25A6J
                      Both the serial number and the TEMIC barcode are in the EEPROM.
                      I have a programmer that can read the 4KB EEPROM of the MC9S12XDT256VAL micro-controller inside.
                      Advice welcomed (i.e. which part of the original module EEPROM content should be cloned into the donor module EEPROM...etc.)
                        radoslaw317
                        you need to clone whole of the data from original unit ( MC9S12XDT256VAL ) to the donor,
                        make sure you erase donor 16 Bit Microcontroller ( MC9S12XDT256VAL ) before writing original data
                        • 2 Offline
                          2 Offline
                          2009 S80 T6 Owner
                          1. Erase donor module EEPROM
                          2. Write the EEPROM content of the original module to the donor module EEPROM
                          Let me give that a try. Thanks muchly!
                            radoslaw317
                            @2009-S80-T6-Owner
                            Thats correct.
                            May i know what type of tool you using?
                            • 2 Offline
                              2 Offline
                              2009 S80 T6 Owner
                              @radoslaw317, I use a UPA-USB programmer.
                                radoslaw317
                                UPA-USB programmer is a worthing to get?
                                I have CG100X but it won't work with Volvo 100% crash date I clear in Volvo cars make wors then was I have one Volvo xc60 to clone srs but i can't find any good programmer
                                can you check if UPA can clone
                                Volvo P/N P31406637
                                Bosch P/N 0 285 012 268
                                thank you
                                • 2 Offline
                                  2 Offline
                                  2009 S80 T6 Owner
                                  @radoslaw317, the UPA-USB programmer goes by microcontroller models (i.e. MC9S12XDT384.) Instead of the SRS module part number, can you provide the microcontroller model inside the module for me to look up?
                                  Thanks.
                                    radoslaw317
                                    NEC IC 70F3466GC
                                      radoslaw317
                                      • 2 Offline
                                        2 Offline
                                        2009 S80 T6 Owner
                                        @radoslaw317, my UPA-USB programmer software is a bit old. Your particular NEC microcontroller is not on the list of supported NEC microcontrollers.
                                        But I suggest you to install the latest free UPA demo version from Elrasoft (https://www.elrasoft.com/download.htm) and see if your microcontroller is supported.
                                        Download the 2 items below:
                                        Free Universal Programmer Analyser - UPA v2.3 Lite 485 KB
                                        Free UPA v2.3 Lite PASSWORD Registration
                                        By the way, I spent quite a few hours without getting good solder connections to the SRS PCB board. In the last 3 months, I succeeded 3 times (read and write) out of 100 attempts with a number of modules.
                                        I will probably contact a professional to write the EEPROM binary file for me instead.
                                        If there are other ways of programming the SRS module (without soldering) such as via the module connector or OBDII port, I would love to hear about them.
                                        Thanks.
                                          radoslaw317
                                          Thank you for Download links.
                                          I mainly specialise with engine ECUs cloning and repairs I have a bit clue how to solder, and I have a professional tool to do it but I don't have many experiences with Airbags
                                          my Programmer SVOD4 doesn't like Airbags but its excellent with ECUs.
                                          For Airbag crash date I am using CG100X but there is no cloning option
                                          if you struggle with soldering I more than happy to help I was ordered genuine UPA Programmer from their website with newest script catalogue, so I hope I going to sort this SRS and make some money on this vehicle
