211 Posts 107 Posters 58.4k Views
    repeq
    replied to ZaanTerror on last edited by
    #41
    @ZaanTerror I installed it and have been using it for a while now, it works great, when could I get a new version of what you're commenting on?
      Vreaper
      ive got a new issue. i dont know what happened. my surface pro 7 seems to have bricked the vida.
      just says starting when i boot up.
      how can i look at whats stopping the server from starting up?
        ZaanTerror
        There are VidaMonitor logs in the C:\VIDA\System.
        But i think you can fix the issue in 2 ways:
        1 - enable Vidamonitor at windows startup and reboot the system so VidaMonitor is started with System rights.
        2 - uninstall VIDA (dont uninstall SQL!), install again and reboot
        V 1 Reply Last reply
          Vreaper
          #44
          @ZaanTerror yeah it works flawlessly on my toughpad too.
          reinstalling it worked,
          if it breaks again ill try to track whats happening better on the system day to day, and when or if it bricks the vida again where i have to reinstall ill atleast report back and share what did it. at this point in time seems like some kinda update. or theres this iobit advanced systemcare software i figure that kinda program coulda messed with the vida unknowingly
          but ill figure out what bricked it on the surface just incase anyone else runs into the problem
          Z 1 Reply Last reply
            SKanev
            Works absolutely brilliantly, one click and everything installs as easy as can be and runs perfect, genuinely outstanding work, tried it on a Dell Precision 5540 running W11 Pro (Version 10.0.26200 Build 26200)
            with a JLR V168 (pro) off AliExpress with the D5T5 drivers on a 2001 S60
              Rikos92
              This is the best Vida I have used in all the years, thanks for the work done.
                sineDko
                I have found myself in need of new VIDA after upgrading my workshop notebook.
                This realease as very good and does everything one needs from VIDA. Thank you
                  ZaanTerror
                  replied to Vreaper on last edited by
                  #48
                  @Vreaper Don't put too much time in this my next version has a new VidaMonitor i created and will fix this issue.
                    rewned99
                    I installed it in 2 VirtualPc in Vmware 25h2..., the installation went fine and it's working so far. I'll connect it to the car and let you know...
                    • T Offline
                      T Offline
                      Tviks
                      I performed a complete uninstallation of the VIDA from a Windows 10 laptop. This installation was really easy compared to the previous original VIDA 2014d version installation and the very multi-step SQL Server upgrade to version 2019. Huge thanks to the creator.
                        Zolika78
                        @ZaanTerror Very, very thank you! After buying a good cable (Mongoose JLR clone) it is working perfectly! Data reading is superfast, live data, etc. Perfect.
                        • O Offline
                          O Offline
                          odder
                          It's been a while since I downloaded it, and this version of Vida works brilliantly! Far more reliable and extremely fast compared to virtual machines.
                            VolvoAugust
                            This post is deleted!
                              klagowski
                              Hi all,
                              I’m running VIDA on Windows 11 in a VM and it fails to start with a database error.
                              Log:
                              The header for file 'C:\VIDA\db\imagerepository_data.mdf' is not a valid database file header. The FILE SIZE property is incorrect.
                              CREATE DATABASE failed. Some file names listed could not be created. Check related errors.
                              ImageRepository attached.
                              Any idea?
                                ZaanTerror
                                replied to klagowski on last edited by
                                #55
                                @klagowski something went wrong during attachment of databases. Or ImageRepository.mdf became corrupted during download/unpack.
                                Please try uninstall - reboot - install.
                                  klagowski
                                  After reinstalling everything, it works without any issues. Thanks!
                                    Beta
                                    #57
                                    @ZaanTerror Can you send me the link to rogephon@gmail.com?
                                      simlick67
                                      REVIEW: WOW!!!! So easy!
                                      Guys, I have been trying the different version of VIDA of the past years, mostly running on Virtual Machines, which sometimes did run fine, but also encountered problems and took a lot of time and reading and effort to get it working.
                                      This makes getting VIDA a dream... it just worked straight out the zip file (I did have 3.5 Network installed already, not the one supplied with the ZIP). I also had my own drivers for the Mongoose interface installed. Running it on a Panasonic toughbook, i5, 16gb of ram.
                                      I've also encountered many people selling their own easy install versions, and for quite a price too. Volvodiag offers a 5 dollar VM option, but again it's so much hassle.
                                      Props to Zaan, this is what a good software tech can do, and in turn makes my life much easier. I don't want to spend hours figuring out if I have the right spec, right software, right verison etc. I just need the software so I can work on my car and get on with my life. This allows you to do that.
                                        Vizual54
                                        Worked like a charm on my newly installed win 11 laptop, Dell latitude 7280, i7, 16gb ram.
                                        Been using VIDA in a vm on Ubuntu with virtual box and it never really worked out very well. Especially with the J2534 which would make the vm crash almost every time.
                                        This worked so much better and was breeze to install.
                                        Lots of kudos to ZaanTerror for making it so easy saving me a lot of time and frustration.
                                          C0mplexed
                                          @ZaanTerror Can you send me the google-drive link to linus.forsman@post.com please?
                                          • 3
                                          • 4
                                          • 5
                                          • 11
