159 Posts 75 Posters 37.8k Views
  • T Offline
    T Offline
    TheBeerHunter
    Very nice! Works like a charm!
    • T Offline
      T Offline
      TheBeerHunter
      wrote on last edited by TheBeerHunter
      #62
      Any new update of your Vida since march 18 (last time I fixed it)?
        marconi63
        The program installed on a laptop and a desktop running Windows11 pro 25H2. It works without any issues.
        Thanks a lot.
          rewned99
          Due to illness, I only got around to testing it now. I connected the car to Vida and it works both via VirtualPC in Vmware and on a physical NTB...
          It's great when it works without problems.
            rewned99
            And yet...I compared it with the modified Vidov 2015A, where there is only a change to SQL2019 and everything is installed via scripts, not in one run...
            I am not a programmer. The responses are basically the same... But this one is easier to install... and works the first time... THANKS
            • O Offline
              O Offline
              otukka12
              Works fine after reinstalling windows. Wasn’t worked with previous setup. I think previous vida version was reason.
              • jbruijsJ Offline
                jbruijsJ Offline
                jbruijs
                @ZaanTerror I really would like to receive the link. Could you please send me this? inboxanoniem@gmail.com
                • Y Offline
                  Y Offline
                  Yurii bihun
                  @ZaanTerror Can you send me the link to bihunyura@gmail.com?
                  • T Offline
                    T Offline
                    teepee
                    Installation on win11 laptop was a breeze. Thank you so much for sharing!
                    • F Offline
                      F Offline
                      Fidda
                      Hi, can I please get a copy too? @ZaanTerror I would really appreciate it! Thank you so much
                      Johnpeter22759@gmail.com
                        Mykoliukas
                        Instalation went smooth. Tested on xc60 2012 with DiCE. Works perfect! Thank you!
                        • L Offline
                          L Offline
                          LukeLucky
                          I just wanted to give a massive shoutout to the creator of this Windows 11 VIDA version.
                          I’ve been struggling with Win7 virtual machines for a long time just to keep my XC60 (2013) in check, but this build is a total game-changer. It runs flawlessly on my Win11 host—no more VM lag or USB passthrough headaches.
                          Everything works perfectly:
                          Seamless login (no issues there!).
                          Full access to all modules (CEM, BCM, PAM, etc. — all green and communicating).
                          Rock-solid stability with the DiCE interface.
                          If anyone is still hesitating: go for it. This is top-tier work that makes Volvo ownership much more enjoyable. Absolute legend! Thanks again!
                            kvavra
                            @ZaanTerror Can you send me the link to k.vavra@seznam.cz
                            Thank you !
                            • ilonapsheI Offline
                              ilonapsheI Offline
                              ilonapshe
                              @ZaanTerror Can you please send me the link to ipshenichnaya6@gmail.com
                              Thank you very much!
                                Vinalile
                                @ZaanTerror Is someone you really can trust, working like a charm, no issues, and no more vm struggles anymore! Big thank you sir!
                                  ilonapsheI Offline
                                  ilonapshe
                                  Hi guys!
                                  Maybe someone can help me somehow with the installation. Idk what I am doing wrong.
                                  So basically my installation process stops with Microsoft SQL server 2025. I changed the .net framework 3.5 in optional features, but it didnt help. Then I decided to install the SQL server 2025 from the https://www.microsoft.com/en-us/sql-server/sql-server-downloads. Got the program work, but the VIDA installation still stops in the same place.
                                  Thought maybe I can install everything from ISSetupPrerequisties. So i did that, even the SQL seems to work from there, but in main VIDA setup.exe it still stays as a requirment and when i start installation i got message
                                  Can someone tell me what i need to do to get VIDA work with me?
                                  Thank you
                                    replied to ilonapshe on last edited by
                                    #77
                                    @ilonapshe what version of Windows are you running? Do you try to replace an older version of VIDA or is it a clean install?
                                    ilonapsheI 1 Reply Last reply
                                    • 3 Offline
                                      3 Offline
                                      314159
                                      Thank you very much, great job!
                                      Very easy installation of the program.
                                        Kaaliperse
                                        Hello
                                        May i get the download link for this perhaps?
                                        BR
                                        Kaaliperse
                                          Smuggler44
                                          Hi
                                          Could i get the download link 🙂
                                          Best regards
                                          Dawid
                                          • 3
                                          • 4
                                          • 5
                                          • 6
                                          • 7
                                          • 8
